May 16, 2017 2:54 PM UTC
I need to give access to type and attribute manager to non org admin users
I have a requirement where a non org-admin users needs to have access to only type and attribute management under an Organization. He should not have access to anything else under organization. Please help with guidance with this customization.
2-Explorer
May 16, 2017 3:21 PM UTC
Org tab is enabled by a validator, the validator checks to see whether you are an administrator, shared team creator or security label manager. So I don't think there is an option to enable the Org tab. Could you elaborate your use case, what specific action will the user be performing in type and attribute manager?
May 29, 2017 5:50 AM UTC
Hi Binesh,
            I also have similar situation.
I am trying this by adding the user into the Type administrator group and by creating the profile for the user.
I am planning to use the URL and custom action to get the same, but with no success.
Following below help center link as well
http://support.ptc.com/cs/help/windchill_hc/wc102_hc/index.jspx?id=WCClassAdmin_TypeMgrGlobalEnumNonAdminAccessEnable&action=show
