Sep 15, 2016 6:24 PM UTC
I NEED TO RUN Creo3 and wildfire 5 with windchill 11 and 9.1
hAS ANYONE EVER BEEN SUCCESSFUL IN USING CREO3 WITH WINDCHILL 11 AND
WILDFIRE 5 WITH WINDCHILL 9.1 ON THE SAME COMPUTER AND THE SAME USER@
mdebowerAnswer
18-Opal
Sep 16, 2016 2:39 PM UTC
I found a Tech Support Article that explains the steps: Document - CS62457
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS62457&source=Article%20viewer
Note that you will need an active PTC support account to access it.
Sep 15, 2016 7:30 PM UTC
Should be possible since Windchill is not running on the same computer as the CAD software.
Use different shortcut icons to Wildfire 5 and Creo 3, each pointing to their own cache file folders.
Then register each CAD program to its respective Windchill server.
Minimum 3 computers required, 2 servers and 1 workstation. Realistically it would be 5 computers, 2 Windchill/Apache servers, 2 dadabase serevrs and your 1 workstation.
ahavassy1-VisitorAuthor
Sep 15, 2016 7:40 PM UTC
‌Ben, thanks for that answer there is one issue and that is how do you set up a seperate cache location for each cad instance. I have never had much luck with doing that but maybe I was doing that wrong.
Sep 15, 2016 8:19 PM UTC
Use different Start-In folders for each version and then it is automatic since the WF_Cache is placed in the starts-in folder. It only becomes complicated when you use the same start-in folders, then you need to use a config.pro setting to set the cache.
Also do NOT use a common config.pro since many settings have changed/ been obsoleted/added between Wildfire 5 and Creo 3.
mdebower18-OpalAnswer
18-Opal
Sep 16, 2016 11:17 PM UTC
‌aawesome this is perfect exactly what I needed
