Nov 7, 2024 9:16 AM UTC
I want to move multiple documents at once.
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.0.0
I would like to move multiple documents at once. Is it possible to do this from a browser, loadFromFile, or a spreadsheet?
Each document I want to move can be identified based on its unique value, so it is difficult to batch move documents from the browser.
複数のドキュメントを一括で移動したいのですが、ブラウザまたはloadFromFileや、スプレッドシートから一括移動は可能でしょうか。
移動したいドキュメントはそれぞれユニークな値を元に特定ができるので、ブラウザから絞り込んで一括で移動ということが難しいです。
    Fadel
    23-Emerald II
    Nov 7, 2024 12:52 PM UTC
    not possible , see https://www.ptc.com/en/support/article/CS35571 .
    use the unique attribute to seach documents and then move from search
    Buiꓘa
    joe_morton
    Nov 11, 2024 8:06 PM UTC
    I would recommend this method:
    You can search for all document numbers separated by semicolon to get them all in one search result. Reference: https://www.ptc.com/en/support/article/CS19312?source=search
    Then you can easily select all the documents from the search and move them where they need to go
    avillanueva
    23-Emerald II
    Nov 11, 2024 8:10 PM UTC
    @joe_morton is right. You can do hundreds of docs in a clip if you can get them into a search result or a folder. Then use multi-select.
    Nov 11, 2024 8:19 PM UTC
    One more option is to write an utility.
    https://www.ptc.com/en/support/article/CS69568
    Regards
    Ajit
