Sep 19, 2011 5:04 PM UTC
IBA String in Change Request
- 5 replies
- 2390 views
- Translate All
We have defined IBA attributes for the Change Request object in Windchill. For example "Justification", this String IBA cannot take more than 500 character. If I remove the single line constraints, the user can write more than 500 char.
[cid:image001.png@01CC76B3.43729CB0]
But then the order of the text totally messes up. PTC tech support says that this is a known issue, but no resolution yet.
Tech support also suggested that we can increase the column length at the database level, but that also has max limit. Has anybody done this?
How do you handle such situation? Any suggestions?
Preeti
Preeti
