Oct 5, 2015 1:58 PM UTC
IBA values in EPMWorkspace are not updated after updating IBA without checkout
Hello to all!
Maybe someone had the same problem!
We are doing IBA update in common space without checkout with this API function :
wt.iba.value.service.StandardIBAValueService.theIBAValueDBService.updateAttributeContainer()
But we have now the problem with EPMDocuments. If document is in the EPMWorkspace, value of the IBA is not updated in EPMWorkspace.
So the new value is only visible in common space. Standard workspace actions (sync or update)  are not upodating this value.
If user changes manually lifecycle state of the object in the common space, value of the IBA is updated also!
Is it possible to trigger  some kind sync or update action with API for EPMWorkspace ?
Vytautas
