Apr 1, 2016 2:42 PM UTC
Identifying software from the "MED- . . ." name?
Is there any method to figure out just what the contents of a PTC CD is from the name?
For example: "MED-60318-CD-101_M030" and the rest as seen here:
Thank you.
ML Starkey
2-Explorer
Apr 1, 2016 2:59 PM UTC
Apr 1, 2016 3:05 PM UTC
Thank you! I wonder why this didn't come up when I searched the support DB . .. oh well!
Apr 1, 2016 3:26 PM UTC
Not unless you know the file codes or have them stored in a file.
You can open the image and then open the version.xml file which will tell what the file is for.
The codes do not change, just the date codes when a new version/build comes out.
All that you listed are for Windchill 10.1 (101) with various build codes (F000, M030).
From your list, I have:
60171 - InfoEngine
60318 - Service Pack
60379 - PDMLink
60418 - Services
60419 - Third Party Software
60423 - Multi-Language Pack
60686 - Index Search
60702 - PTC Solution Installer
60703 - JAVA JDK
60704 - Business Reporting
607041 - Windows Server
607042 - Solaris
607043 - HP-UX
607044 - AIX
607045 - RH Linux
607046 - Language Pack
60707 - Workgroup Managers
60756 - Point Release
60757 - Help Center
60800 - Directory Services
Some you did not list:
60310 - ProjectLink
60319 - ECAD WGM
60430 - ProductView
60481 - Aphelion DS
60482 - PV Doc Support
60758 - ProductView Client
60795 - Product Analytics Process Advisor
60898 - Common Base
61006 - CPS sets
Hopefully you can fill in the rest or some else can.
Apr 1, 2016 3:45 PM UTC
Thanks, that is helpful. Anything to narrow down the subject and 'crack the code' here is exactly what I need.
