Mar 4, 2020 4:02 PM UTC
Identity column, what controls this format?
I have a soft type of part that is representing a Material. We then have a configurable link connecting the part and the material. We have an Alias Attribute that shows the materials that are linked to the part on a Structure view. Issue is the value that is displayed is the object's identity which is in the format <number>, <name>, <organization> I only want to see the name, but still want the hyperlink to the object.
Is it possible for a soft-type
Mar 9, 2020 7:45 PM UTC
Hi  sdrzewiczewski,
What does your Alias Attribute look like> If you make your Alias Attribute with the Data Type Object Reference, and the Mapping ending with the name instead of the identity, do you get an error message?
Apr 7, 2020 5:02 PM UTC
I did use an object reference. Below is what I settled on. If I remove ~number i get a hyperlink, but the link URL is not what I want to show. The other issue is that it points to the Part Master, which is not useful. I you can then point that to the part, but it will show all iterations, again not useful. So settling on the below format, i lose the hyperlink, but i get a format that is acceptable.
masterReference^wt.part.WTPartMaster~roleAObject@wt.configurablelink.ConfigurableMastersLink~roleBObject^wt.part.WTPartMaster~number
