Aug 2, 2017 5:36 PM UTC
IE 11 with Windchill 10 and Creo 2
In testing for Windchill 11, I had IT install IE 11.
In an external web browser, I have no issues with IE 11 and Windchill 10.
In the embedded Creo browser, I cannot get the workspace to load.
Is there a work around for this condition?
Some setting in IE11 that will force it to behave like IE 8 or 9?
I can capture the long runing script errors and post later, if needed.
Aug 3, 2017 6:58 AM UTC
One of the reason may be you are using IE 11 in Enterprise mode.
IE11 Enterprise mode is not supported with Windchill 11.0, so need to change it to Edge Mode. Check with your IT Team for same and ask them to exclude Windchill URL from Enterprise mode.
Refer PTC CS218340  for more details.
Aug 3, 2017 8:14 AM UTC
You can try to use the setting "Сompatibility View" in Internet Explorer 11.
BenLoosli23-Emerald IIIAuthor
Aug 7, 2017 3:49 PM UTC
Compatibility mode works fine for IE11 on an external browser.
My issues is with the internal Creo browser which does not work with IE11!
Aug 7, 2017 3:56 PM UTC
You can try )
