Oct 20, 2022 12:21 PM UTC
If possible to show the windchill check in,check our state in 3D window?
Hello I am a new user for Creo and windchill,
Is there any solution to show the windchill check in, check out state in 3D view,
Yes there is a inner brower we can check the inforamtion in a big table, its easy for small project;
But for large project, the table is not very easy for human be .
So if there is any solution to show the state in 3d window, by color?
Or some special icons use in structural tree?
Thanks in advance!
22-Sapphire I
Oct 21, 2022 3:16 PM UTC
Are  you possibly asking if the check out status, etc. can be seen within Creo Parametric while working on a 3D model? If so, the answer is:
- not visible in the 3D models themselves
- one can add columns at any time to the Creo model tree that lists this along with other info from Windchill
Look at adding columns to the model tree.
https://support.ptc.com/help/creo/creo_pma/r6.0/usascii/#page/fundamentals%2Ffundamentals%2Ffund_six_sub%2FAbout_Model_Tree_Status_Display.html
https://www.ptc.com/en/support/article/cs360742?language=en&posno=1&q=creo%20model%20tree%20columns%20windchill%20status&source=search
https://www.ptc.com/en/support/article/cs309327?language=en&posno=5&q=creo%20model%20tree%20columns%20windchill%20status&source=search
https://www.ptc.com/en/support/article/CS148947
Oct 21, 2022 1:34 PM UTC
Please provide an example of what you are asking for?
In Windchill browser, you can see the state of all parts in a view of the folder that holds the files.
In the Structure tab of an assembly, the state is shown by default.
Sulibo14-AlexandriteAuthor
Oct 24, 2022 5:02 AM UTC
Thank you @BenLoosli ,
I think its version problem,
My creo need add colmun by manual as @MikeLockwood  show in his answer.
22-Sapphire I
Oct 24, 2022 4:34 AM UTC
Thank you @MikeLockwood , Although my English is bad, you still get what I want to ask for.
and I think can check the information in model tree is an  acceptable solution.
Thanks very much!
