May 16, 2016 10:51 AM UTC
If the relation or link between WTPart and WTPartMaster is WTPartUsageLink then what is the relation or link between two WTPart objects ?
Hi All,
Can anyone tell me the link between two WTPart objects.
if the Relation or link between WTPart and WTPartMaster is - WTPartUsageLink
                                   WTDocument and WTDocumentMaster is - WTDocumentUsageLink
                                   WTDocument and WTDocument is - WTDocumentDependencyLink
So kindly tell me the link object name ?
Thanks and Regards,
Aditya Achanta
May 16, 2016 11:38 AM UTC
Hi Aditya,
As per the below support article there is no Link object listed between the two WTPart objects.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS131357&art_lang=en&posno=2&q=part%20links&source=search
aachanta15-MoonstoneAuthor
May 16, 2016 11:42 AM UTC
Hi Bhagirath,
I had seen that article before itself.
Like I was just thinking if there is any other link between two WTPart Objects ?
Thanks and Regards,
Aditya Achanta
May 16, 2016 12:04 PM UTC
Aditya ,
Below  are the two links between WTParts
  1. WTPartAlternateLink
  2. WTPartSubstituteLink
You can see wt.part Package in java doc it will give ou all link classes. Hope it helps
Shreyas
