Feb 29, 2024 9:46 AM UTC
If we release any WTDocuments/EPM Documents through change process that are publishing to ERP
I am using Windchill Enterprise Systems Integration Release 11.1 and Datecode with CPS M020 CPS30
Our requirement is to release part and BOM to ERP through a change process(Promotion Request), but if we release the WTDocument/EPMDocument individually through the change process RTM workflow triggers.
How to release only parts/BOMS to ERP(RTM workflow needs to be trigger) using the change process. If we release the WTDocument/EPMDocument through a change process RTM workflow won't be trigger. Help us to configure this issue.
Feb 29, 2024 9:54 AM UTC
Any preference settings to avoid publishing WTDocument/EPM Document to ERP.
MarcoTosin
Feb 29, 2024 10:14 AM UTC
There are dozens of preferences that can be set for the ESI configuration.
Marco
Feb 29, 2024 12:53 PM UTC
If we remove the Promotion Request Configuration Specification State to Empty and Change Notice Centric State to Empty, only Lifecycle States Triggering Publication of a Document and Lifecycle States Triggering Publication of a CAD Document set to "RELEASED"
if we set the preference settings like this, when we do the change process for WTDocuments/EPM Documents RTM workflow won't triggers, and it will works, but if we release the part/BOM through change process, in that case RTM workflow won't triggers,it only triggers for set state.
how to launch the RTM workflow automatically while publishing the part/BOM through change process not for EPM Document / WT Document
