Mar 2, 2017 6:37 AM UTC
illustrate insert JT
Hello, I can not use illustrate to insert a JT profile,the problem is as follow:
"Path to log file: C:\Users\YANGBI~1\AppData\Local\Temp\PTCg032c6gg0vuq0\IMPg03im5ug0vuq0\conversion.log
jt2pv - Version : Creo 3.0 - M030 (13.2.30.38) x86e_win64
Copyright (C) 2000-2015 PTC Inc. All Rights Reserved.
jt2pv Error:3000: Failed to open registry file "D:/x86e_win64/jtopen/recipe/jt2pv.pvr".
jt2pv Error:10001: Failed to load "jt2pv" default recipe file [D:/x86e_win64/jt"
Can you solve this issue?
