Feb 25, 2026 3:22 PM UTC
Import/Export Management
Version: Windchill 13.0
Use Case: I am performing a an import of data from a source environment. Using the import/export management tool, I am presented with the following error when trying to do the import. "WTDocument: 123 ( 000073 ) A.2" cannot be imported because the revision "A" is invalid" The issue can be overcome when I check the "Resolve overridable conflicts" check box. I have checked the version sequence on both the source and target environment and they are identical.
Description:
Can anybody explain why I am receiving this error message?
Mar 16, 2026 7:10 PM UTC
Hi. I think I've managed to resolve this. Despite the error message I was getting, I don't think the cause was anything to do with what the message was indicating. It seems that my workflow and lifecycle that the object type that import was trying to create included state names that had not been added to the correct modeled enumeration list. Once this was resolved and the workflow and lifecycle were usable, the import created the objects no problem.
MarcoTosin
Feb 25, 2026 3:30 PM UTC
Feb 25, 2026 5:10 PM UTC
Hi. Thanks for getting in touch. I don't believe the info in the first URL explains why this error occurs - have I missed something? The second URL does but does not make sense to me as I have compared the version schemes in both of my environments and they are identical.
MarcoTosin
Feb 25, 2026 5:14 PM UTC
