Jan 26, 2022 3:59 PM UTC
Import from Spreadsheet File Validation Error "Concurrently Updated"
I'm using the Import from SpreadSheet command on Windchill 11.1
2 month ago it was working perfectly but I now encounter difficulties.
I use a recently exported file as template.
At the File Validation step, I have the following Error :
The Log file generated contain only the following lines :
Uploading Excel file on Windchill server from primary content of the import job...
Sheet 1 "BOMSheet1":
PREVIEW RESULT : FAILED
Any idea what can "concurrently updated" mean for my Import Job file ?
Thanks.
François
Jan 26, 2022 4:14 PM UTC
Perhaps check in the Import Job Monitor for any that are still running, defining or any other state other than done/complete, and kill those jobs.
FBury5-Regular MemberAuthor
Jan 27, 2022 1:56 PM UTC
Thanks, I tried but no Job seems to be in execution.
But we may have a idea of what happens.
I work on a development instance of Windchill and not on the production one.
Currently on the dev instance there is no Worker Agent started, whereas at least one was probably running previously.
If the "Import from Spreadsheet" process request a Worker, it's probably the root cause ...
Jan 27, 2022 10:01 AM UTC
 Hi François,
Read the following article - "Import from Spreadsheet does not import as "The type 'WCTYPE|wt.part.WTPart|CustPart|CustPart' cannot be imported into the same system.” in Windchill PDMLink": https://www.ptc.com/en/support/article/CS178975
Jan 27, 2022 1:59 PM UTC
Thanks I read this article.
My case seems different cause the Spreadsheet scan abort at the very beginning.
My log file is only 3 lines long.
