6-Contributor
Apr 8, 2024 1:21 PM UTC
Import from spreadsheet Predecessor Revision/View
When importing parts using import from spreadsheet functionality, it throws this error regarding the Predecessor Revision
any ideas regarding this error?
Thank you!
HelesicPetr
Apr 11, 2024 7:37 AM UTC
Hi @Ifriyaz
You can create any IBA attribute what you want in the Type&Attribute Management. Windchill administrator should help you to solve this isse.
Easier way is to remove this input from your source xls file.
PetrH
HelesicPetr
Apr 8, 2024 1:58 PM UTC
Hi @OD_10839055
Check the input xls if there is this attribute. It seams that you import spread sheet that contains IBA attribute that does not exist in your system.
PetrH
Apr 9, 2024 9:14 AM UTC
If the predecessor revision attributes does not exist in the system, how can it be added?
Thank you
HelesicPetr
Hi @Ifriyaz
PetrH
