7-Bedrock
Apr 20, 2026 10:05 AM UTC
Import or Load Part Instances
Hi all,
I have the Part Configuration object. I have to load / bulk create 100’s of Part Instances with Serial Nos, by giving the serial nos and basic info in an excel sheet or .csv sheet.
Is this possible? We are in Windchill 12.1.
Alternatively, is it possible to create a new WRS domain for Part Instance and define some custom PUT/POST functions in it?
Any experience on how this can be achieved.
Best Regards
Hari
Apr 22, 2026 9:18 PM UTC
What have you tried so far? Have you created a part with an instance and exported it? Have you looked at the loadfile functionality?
7-Bedrock
May 7, 2026 9:12 AM UTC
Hi Bryan,
Import via load file for Part Instance is not supported, refer this articles.
https://www.ptc.com/en/support/article/CS168432
Export option for Part Instance is provided from Structure tab , similar to Part Structure export.
Iam thinking if WRS should help here in loading Part Instances.
What do you think?
Best Regards
Hari
May 7, 2026 11:53 PM UTC
Hi, looks like the only way to achieve what you are trying to do is extend WRS.
avillanueva
23-Emerald II
May 12, 2026 11:14 AM UTC
You can write your own load class and method. Also found this:
https://www.ptc.com/en/support/article/CS352074?source=search
Look at the WTProductInstance2 class.
Catalina
Community Manager
May 21, 2026 7:12 AM UTC
Hi ​@HV_14518816
I wanted to see if you got the help you needed on your post:
If so, please mark the appropriate reply as the Best Answer or please feel free to detail in a reply what has helped you and mark it as the Best Answer. It will help other members who may have the same question.
Best regards,
Catalina | PTC Community Manager
