May 11, 2017 8:48 AM UTC
Import problem in the workspace
I have a problem when I try to import Creo objects (prt, drw and asm) into my workspace, the import fails and I do not find any information in the event manager.
Is there a special configuration to set up to have this information in the event manager?
Do you have an idea of why an import can fail?
Thanks in advance.
2-Explorer
May 15, 2017 1:58 AM UTC
I remember seeing this issue. Could you change the "Start In" directory of Creo set to a network file system or a file system which is not write ready. Right Mouse Click on Creo shortcut and change the startin directory to a location which is writable
TomU
May 11, 2017 4:55 PM UTC
The workspace import uses Creo to do the actual import.  Can you manually open the files in Creo?  Is it possible the files are from a newer version of Creo than what you have?
May 12, 2017 6:30 AM UTC
First of all, thank you for helping me.
To answer your question:
1. The files open well in Creo and I am able to save them to see them in my workspace. But this action would take a lot of time because I have several hundred objects (prt, drw and asm) to import.
2. All the objects I am trying to import are of the same version as my Creo (CREO 3.0), even lower.
The thing I do not understand is that I can not find any information in relation to the import failure in my event manager.
May 13, 2017 3:42 AM UTC
Here are couple of tools which help in bulk/mass upload of ProE data to Windchill:
-Amol
2-Explorer
May 15, 2017 7:50 AM UTC
Thank you Binesh Kumar,
I have copied my folder i would to import on my desktop, because the folder I try to import are located on a server who are not writable.
And now i'm able to import my objects without problem.
