Dec 1, 2014 6:11 PM UTC
Import types and attributes from one wc environment to another
Hi!
I have exported all types and them attributes (all soft types for WTPart) through windchill wt.load.LoadFromFile utility. But when export is going on I have an exception like following:
com.ptc.core.lwc.server.TypeDefinitionLoader wcadmin - (endProcessTypeDefinition):
wt.util.WTException: Attributes ' —' and 'null' on wt.part.WTPartreferr to the same iba definition.
at com.ptc.core.lwc.server.cache.AttValidatorHelper.validateDuplicateIbaUsage(AttValidatorHelper.java:880)
at com.ptc.core.lwc.server.cache.AttValidatorHelper.validateAllAtts(AttValidatorHelper.java:859)
at com.ptc.core.lwc.server.cache.AttHelper.persistAttDefs(AttHelper.java:216)
at com.ptc.core.lwc.server.cache.TypeDefinitionManager.persistTypeDef(TypeDefinitionManager.java:895)
at com.ptc.core.lwc.server.cache.TypeDefinitionManager.updateTypeDef(TypeDefinitionManager.java:1509)
at com.ptc.core.lwc.server.StandardTypeDefinitionService.updateTypeDef(StandardTypeDefinitionService.java:193)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at wt.services.ServiceFactory$ServerInvocationHandler.invoke(ServiceFactory.java:399)
at $Proxy12.updateTypeDef(Unknown Source)
at com.ptc.core.lwc.server.TypeDefinitionLoader.endProcessTypeDefinition(TypeDefinitionLoader.java:804)
at wt.ixb.handlers.netmarkets.CsvIxHandler.invokeLoad(CsvIxHandler.java:543)
at wt.ixb.handlers.netmarkets.CsvIxHandler.createObject(CsvIxHandler.java:239)
at wt.ixb.publicforhandlers.ClassExporterImporterTemplate.importElement(ClassExporterImporterTemplate.java:415)
at wt.ixb.publicforhandlers.ClassExporterImporterTemplate.importElements(ClassExporterImporterTemplate.java:539)
at wt.ixb.publicforapps.Importer.importElements(Importer.java:1456)
at wt.ixb.publicforapps.Importer.importElement(Importer.java:1428)
at wt.ixb.publicforapps.Importer.doRealImport(Importer.java:1193)
at wt.ixb.publicforapps.Importer.finalizeImport(Importer.java:507)
at wt.load.StandardLoadService.importData(StandardLoadService.java:825)
at wt.method.MethodResultWriter.writeExternal(MethodResultWriter.java:151)
at wt.method.MethodResult.writeExternal(MethodResult.java:226)
at java.io.ObjectOutputStream.writeExternalData(ObjectOutputStream.java:1426)
at java.io.ObjectOutputStream.writeOrdinaryObject(ObjectOutputStream.java:1398)
at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.java:1158)
at java.io.ObjectOutputStream.writeObject(ObjectOutputStream.java:330)
at sun.rmi.server.UnicastRef.marshalValue(UnicastRef.java:274)
at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:313)
at sun.rmi.transport.Transport$1.run(Transport.java:159)
at java.security.AccessController.doPrivileged(Native Method)
at sun.rmi.transport.Transport.serviceCall(Transport.java:155)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:535)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:790)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:649)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
Dec 2, 2014 2:44 PM UTC
Hi guys, thanks for your replys. I have solved it. The problem was there: in the wnc env, where i try to import data WTPart already have an attribute that I want to import. I have add this attribute 2 months ago and forgot about it. After deleting it, import have went nice.
Dec 1, 2014 8:19 PM UTC
Sorry, I have this exception when import is going on
Dec 2, 2014 9:45 AM UTC
Hello!
Not sure if this will help but we have found out in Windchill 10.2 M020 CPS4 you need to have the below settings in order to get it right:
<csvmode>3</csvmode>
<csvExportAncestorTypes>true</csvExportAncestorTypes>
Best regards,
Peter
Dec 2, 2014 2:45 PM UTC
Peter, what this mode will give?
