Nov 15, 2023 1:59 PM UTC
In edit mulitple object any ways to upload the atatchment for the part as well
HI,
I have around 100 parts create in PLM, which will have individual attachments. Is there anyways i can add easily instead of editing each parts and attaching the document ?
avillanueva
23-Emerald II
Nov 15, 2023 2:04 PM UTC
This is well in scope for a load file.
https://support.ptc.com/help/wnc/r12.0.2.0/en/#page/Windchill_Help_Center%2FWCDataLoad_LoadLegacyUseLoadFromFileUtility.html%23
You will spend some time getting the format right and this does need to be loaded at the server level. But you should be able to take an Excel list of attributes to translate into an XML file that can be loaded. The content can be loaded as well.
Anand_G10-MarbleAuthor
Nov 15, 2023 2:12 PM UTC
Do we have any excel list where i can edit this ?
18-Opal
Nov 28, 2023 8:13 PM UTC
Yes, if you can create a file that maps the part to the file you want attached I could write a utility that you’d run from a Windchill shell that would get the job done.
The utility can attach WITHOUT iterating the part if that’s desired.
If interested send me a private message with your work email address and we’ll get the ball rolling.
David
