May 31, 2016 4:19 AM UTC
In terms of performance, what is it like running Windchill 10.2 in a virtualized environment (e.g., VMware vSphere)?
According to the following guide , it seems that Windchill running well in a virtualized environment
   http://www.vmware.com/files/pdf/techpaper/PTC_Deployment_Guide.pdf‌
Questions:
     1. Are there some folks who run their Windchill 10 Production system in a virtualized environment?
     2. What are pros and cons of running in a virtualized environment?
Thanks for the help in advance.
sknoxAnswer
May 31, 2016 8:09 PM UTC
We run both the Application and Database servers in VM. We are on 10.2 M030 CPS15 (as well as test servers, wouldn't do it any other way)
As far as performance we did have an issue early on with intermittent performance, however after PTC looked at it they notified us of a bug with one of the NIC drivers in VM (switch virtual NIC from VMXNET3 to E1000 / E1000E), so once we changed that we've had zero issues. Advantage wise, if I need to restore the system its easy with snapshots.
TomU
May 31, 2016 6:33 PM UTC
We've never run Windchill in a non-virtualized environment.    I can't imagine why you would want to with all the benefits of virtualization except maybe in extremely large deployments.
sknox12-AmethystAnswer
18-Opal
May 31, 2016 8:17 PM UTC
We currently are running production and test servers in MS Hyper-V 2012R2 quite happily.   As others have mentioned some of the benefits of VM, I won't repeat those.
Oh, we also run off-site at a data center.  Just last week they migrated us to newer hardware, and we didn't even have a drop in service.  Bonus!
Windchill  10.1 m040
Cat1-VisitorAuthor
Jun 3, 2016 12:26 AM UTC
Thanks for the information. I will update how it works in a virtualized environment.
