Rocket_Max
Jan 16, 2017 2:59 AM UTC
In windchill 10.2 M030-CPS 09, workflow hangs on with error(For instance: when activity A finish, activity B not start), and will go on after reset windchill server. No error in WfPropagationQueue, WfUserWorkQueue, WfUserWorkQueue
Error Info:
Log1
2017-01-16 08:15:07,355 ERROR [WfPropagationQueue.PoolQueueThread-1808] wt.queue.PoolQueue.WfPropagationQueue Administrator - Queue Entry 367019: Exception occured
(wt.access.accessResource/19) wt.access.NotAuthorizedException: 注意: 受保护的操作。您没有执行该操作的必要授权。如果您认为不应当收到这一消息,请联系管理员。
at wt.queue.QueueMonitorHelper.queueCheckAccess(QueueMonitorHelper.java:466)
at wt.queue.QueueMonitorHelper.getWtQueue(QueueMonitorHelper.java:376)
at wt.queue.QueueMonitorHelper.getWtQueue(QueueMonitorHelper.java:326)
at wt.queue.QueueMonitorHelper.getWtQueue(QueueMonitorHelper.java:321)
at wt.queue.QueueRunnable.suspended(QueueRunnable.java:111)
at wt.queue.QueueRunnable.run(QueueRunnable.java:134)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
2017-01-16 08:15:07,355 ERROR [WfPropagationQueue.PoolQueue] wt.queue.PoolQueue.WfPropagationQueue  -
at wt.queue.RandomAccessQueueThread.suspended(RandomAccessQueueThread.java:519)
at wt.queue.RandomAccessQueueThread.execEntries(RandomAccessQueueThread.java:465)
at wt.queue.RandomAccessQueueThread.run(RandomAccessQueueThread.java:361)
Log2
2017-01-16 08:15:20,981 ERROR [ajp-bio-8011-exec-94] wt.method.client.httpgw huweijie -  MethodRequestHandler Exception: An exception occured while processing the request.
  1. java.lang.NoSuchMethodException: wt.enterprise.URLProcessor.templates(wt.httpgw.HTTPRequest, wt.httpgw.HTTPResponse)
at java.lang.Class.getMethod(Class.java:1670)
at wt.httpgw.HTTPServer.processRequest(HTTPServer.java:321)
at wt.httpgw.MethodRequestHandler.handleRequest(MethodRequestHandler.java:58)
at wt.httpgw.HTTPGatewayServlet.serviceWithoutFilters(HTTPGatewayServlet.java:336)
at wt.httpgw.HTTPAuthGatewayServlet.serviceWithoutFilters(HTTPAuthGatewayServlet.java:86)
at wt.httpgw.FilterChainImpl.doFilter(FilterChainImpl.java:90)
at wt.session.SessionContextDestroyer.doFilterInternal(SessionContextDestroyer.java:122)
at wt.session.SessionContextDestroyer.doFilter(SessionContextDestroyer.java:162)
at wt.httpgw.FilterChainImpl.doFilter(FilterChainImpl.java:77)
at wt.httpgw.HTTPGatewayServlet.service(HTTPGatewayServlet.java:235)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at com.ptc.jws.servlet.filter.WsdlServletFilter.doFilter(WsdlServletFilter.java:61)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at wt.httpgw.filter.WTContextBeanFilter.doWithWtContextBeanHandler(WTContextBeanFilter.java:104)
at wt.httpgw.filter.WTContextBeanFilter.doFilter(WTContextBeanFilter.java:58)
at wt.servlet.CompressionFilter.doFilter(CompressionFilter.java:294)
at wt.servlet.RequestInterrupter.doFilter(RequestInterrupter.java:335)
at wt.servlet.ServletRequestMonitor.doFilter(ServletRequestMonitor.java:1652)
at wt.servlet.ServletRequestMonitorFilter.doFilter(ServletRequestMonitorFilter.java:56)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:423)
at org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:190)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:620)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:316)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:65)
at org.apache.tomcat.util.threads.TaskThread.run(TaskThread.java:103)
What I need:
1.how to find workflow by queue entry num?
2.how to find root cause?
Jan 16, 2017 10:31 AM UTC
1. How to find workflow by queue entry number?
Navigate to Site > Utilities > Queue Management
Click on View Information icon in WfPropagationQueue
Search for Queue entry 367019
Click on link to workflow
2. How to find root cause?
In workflow process manager search for last activity in grey or activity in red
Workflow activity in grey = completed activity
Workflow activity in green = started activity
Workflow activity in red = stopped activity
Rocket_Max
Jan 17, 2017 1:10 AM UTC
Thanks for your reply.
I can't find queue entry in WfPropagationQueue or other queue, so I try to find it in database by using SQL, but I can't  associate queueentry with workflow. Do you have any good advice?
I check workflow process manager, but no activitys in grey or red, as I said activity A(green) finished and activity B(no colour) not start.
Jan 17, 2017 9:00 AM UTC
Enable the logger of this class, you can use the following command line on a Windchill shell or do it through the system monitor:
windchill wt.util.jmx.SetLogLevel -all wt.queue.QueueMonitorHelper ALL
Note that to enable the logger you usually just need the name of the class. This should allow you to see the the queue which is having the issue or more information.
It looks like the user does not have access to the queue, does this happen with an administrator user (wcadmin)?
