Jan 2, 2015 9:51 AM UTC
In Windchill Layout Declaration of the Planes in the part is getting lost.
Hello Windchill Community Members,
(Procedure A)
1) I am using inbuilt Creo 2.0, Windchill browser.
2) In Project Side Workspace, using Tools-> Import to Workspace, from Local drive loacation (D:\Trial Folder).
3) When I import all my part, assembly, layout & Skeleton, in one stroke import process. The Layout declaration of my part (part_1.prt) with all Planes, which I declared as A,B,C getting lost. (Planes Declaration A, B, C is lost- When I refer Model Intent-Declare-List Decl-Screen)
This happens only when I import all in one stroke.
(Procedure B)
But, If follow following sequence;
1) I import other parts first, except layout(lay0001.lay) , then remove ghost layout (lay0001.lay) from workspace
2) Again import the layout (lay0001.lay) in same workspace with clicking the (Import to Workspace window-Specify Option-) Reuse common space part, the the layout declaration is not getting lost.
I fill that with (Procedure A), the part (part_1.prt) planes declaration should not be lost. Please suggest if any other best procedure, if any.
Attaching herewith "LOST_DECLARATION.zip" for your trial reference.
Vinit Kadam
