Sep 14, 2023 9:55 PM UTC
Include JDNI adapter in Rehost utility using WIndchill 11.2.1.2 on Linux
Has anyone been able to successfully include a custom JDNI adpater in rehost? There's a comment in the rehost.properties file:
############################## Adapter Changes############################
#   "administrative" is the default suffix for the AdministrativeLdap adapter
#   "enterprise" is the default suffix for the EnterpriseLdap adapter
#   Additional domains for other adapters can be added by specifying the adapter
#      name as a suffix. Connection information for those adapters is specified by
#      adding a set of LDAP connection properties with the same suffix.
Then it uses the default "administrative" and "enterprise" in the properties:
target.ldap.renameAdapter.enterprise=com.<company>.EnterpriseLdap
target.ldap.renameAdapter.administrative=com.<company>.Ldap
So that leaves me to believe that that if I had a suffix for the JDNI adapter I could specify:
target.ldap.renameAdapter.<JDNI adpater suffix>=com.<company>.<JDNI adapter name>
But how do I create a JDNI adapter suffix?
This is preventing me from upgrading to 12.2
HelesicPetr
Sep 18, 2023 5:50 AM UTC
Hi @CS_2700254
So tell them that you need same rehost on Windchill 12
I believe that you would have same issue on the supported version.
PetrH
ScottMorris
Sep 15, 2023 2:42 PM UTC
hi, if you are not getting a quick response from the community on this specific technical issue, please reach out to PTC Technical Support for additional information.
Sep 15, 2023 5:41 PM UTC
Hi Scott, I tried PTC technical support first but they said they do not support Windchill 11.* any more
HelesicPetr
Hi @CS_2700254
PetrH
