Feb 23, 2023 9:07 AM UTC
Inseparable assembly
Hi
I have the requirement in a Java api program to check if an assembly is set inseparable in Creo. Does anyone know what property or method this is  ?
avillanueva
23-Emerald II
Feb 23, 2023 9:14 PM UTC
I do not have that enabled but I do see an "Assembly type" on the WTPart that calls out "Inseparable". If not directly captured in the EPMDocument, you can find it by the assiciated WTPart I would assume. Haven't played with this much.
avillanueva
23-Emerald II
berny2U13-AquamarineAuthor
Feb 28, 2023 6:18 PM UTC
Hi
Sorry for the late reply.
I do not find it directly for the EPMDocument but do find it for WTPart. And I took it from there. Thanks for your help, cheers.
