Nov 16, 2018 9:55 AM UTC
Install critical patch set radio button is disabled
I am using Windchill 11.0 M030. I had not installed CPS initially. I downloaded the CPS09 and tried to update Windchill. After running the setup file for update, I am unable to install the Critical patch set since the radio button is disabled. What should be done?
TomU
Nov 16, 2018 1:37 PM UTC
There's an article for that.  Read this:  https://www.ptc.com/en/support/article?n=CS37842
