Installation problem - Windchill 11.2
- 7 replies
- 3645 views
- Translate All
I have specified correct directory path of Microsoft sql server but still I am getting this error
Invalid SQL Server install location specified or SQL Server database server software was not installed on local system. The path must contain the following for SQL Server 2014: "SQL_SERVER_HOME\MSSQL12.INSTANCE_NAME\MSSQL\Binn\sqlservr.exe" where SQL_SERVER_HOME is the SQL Server installation directory. For example: C:\Program Files\Microsoft SQL Server.
SQL Server Installation Directory
Specified SQL Server Data Files directory is invalid. Database user has insufficient permission to read, create, update and delete in the folder.
SQL Server Data Files Directory
Invalid SQL Server Client install location specified. The path must contain the following "SQL_SERVER_CLIENT_HOME\Binn\sqlcmd.exe" where SQL_SERVER_CLIENT is the SQL Client installation directory. For example: "C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\110\Tools" for SQL Server 2014.
*SQL Server Client Installation Directory:
