Feb 25, 2019 2:44 PM UTC
Installing CreoView
Does someone have a quick reference guide to installing CreoView 4.1 so it may be downloaded and installed from Windchill 11.0?
I need to get the download configured so the users can go to Quick Links - Software Downloads and then get the stated version of CreoView for installation.
BenLoosliAnswer
Feb 25, 2019 6:52 PM UTC
How frustrating!!!
I tried a number of times to install CreoView in Windchill and when I selected the CreoView location, it come back with Add staging folder.
Open a call with PTC tech support and walking through the same steps and low and behold it accepts the CreoView folder for staging and is now installing.
3-Newcomer
Feb 25, 2019 3:15 PM UTC
Hi Ben,
If CreoView is not available from Downloads, thenyou might have not installed CreoView (while installing Windchill):
Does it appear in Windchill version ?
If so, then it might just be the property missing: CS257489
Otherwise, you have to run PSI and add the PTC Creo View item.
Florent
BenLoosli23-Emerald IIIAuthor
Feb 25, 2019 4:02 PM UTC
I did not install it when I did Windchill because I cannot get the right software into a staging folder.
When I check that box and continue, PSI is looking for:
PTC Creo View Clients - MCAD & ECAD 11.0+   F000+
I cannot find any download with that title! Where do I find what the PSI is looking for?
What I do have downloaded is:Creo View 4.1 Clients (Lite, MCAD, ECAD)
Most Recent Datecode
Datecode: F000
3-Newcomer
Feb 25, 2019 4:22 PM UTC
Hum,
which version of Windchill 11.0 are you working on ?
You can have a look on CS236395: Creo View, Creo Illustrate and Creo View Adapters Versions Certified with Windchill 11.0 Critical Patch Sets
2 weeks ago, I successfully installed Windchill 11.0 M030 CPS13 with CreoView 5.1
Florent
