22-Sapphire I
Apr 5, 2017 6:05 PM UTC
Installing WC 11 M020 - Service Pack DVD?
Attempting to install.  Can't figure out what software download it's looking for for Service Pack - please see attached.  I've installed Windchill many, many dozens of times - never ran into this before.
22-Sapphire I
Apr 5, 2017 7:56 PM UTC
Aha - got help from tech support.  Have to use the solution installed launched from the CPS 020 bundle.
22-Sapphire I
Apr 5, 2017 8:37 PM UTC
So.... Install successful starting solutions installer this way.  But, had to create a database manually (Oracle) first.  Not sure why but it allowed it to get past OCU.  May be helpful to others.
Apr 6, 2017 7:33 AM UTC
Did you set SQLNET.AUTHENTICATION_SERVICES to "NONE" in the sqlnet.ora file?
By default the property SQLNET.AUTHENTICATION_SERVICES is set to "NTS".
22-Sapphire I
Apr 6, 2017 3:06 PM UTC
I had to reboot for another reason in the middle of the install and so wiped out what I had and started over, with everything removed and clean.  On second try, it all worked perfectly - starting with "setup" under the CPS01 bundle DVD, not the Solutions Installer.
