Nov 7, 2016 2:12 PM UTC
Installing Windchill 11 on a test machine and I am getting this error:javasdk installer appears to have failed to start. Its PTC and/or XML log is missing
Anyone have the simple solution to this error? I am running PSI as root and have full rights to the staging directory. As soon as I click on begin install, I get the error about javasdk can't continue and it stops right there. The interesting thing is that I installed Windchill 11 on another clone of the server without getting this error. From what I read, it could be a rights issue somewhere, but I am running this as root. Anyone have any ideas on what to look for? Thanks in advance!
Nov 14, 2016 4:47 PM UTC
Hi Mitch,
Can you check if the below article helps. If not, can you share the logs.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS241829
Bhushan
22-Sapphire I
Nov 14, 2016 4:53 PM UTC
Are you by chance installing on a workstation for test, not a server?  I always play with Windchill a lot at home - using a personal laptop
I got a new laptop with Windows 10 on it recently and found that you cannot run the installer using Windows 10 yet - had to set up Win 7 professional.  All installed ok.
mkohn4-ParticipantAuthor
Nov 14, 2016 4:57 PM UTC
Actually, since that time I "punted" and found my M010 files and got past that point. DK if my javasdk files were corrupted on not. Thanks anyways to all.
Jan 9, 2017 2:15 PM UTC
Hi Mitch,
are you fixed this problem ?, I have the same bugs when I try to install windchill in linux Red Hat with PSI Bundle CPS06.
Regards
Jan 9, 2017 2:38 PM UTC
I fixed it by installing Windchill 11 M010.
