Jun 29, 2020 12:49 PM UTC
Installing Windchill in Windows 10 os
Is installing Windchill 11.2 supports Windows 10 os possible?
Jun 29, 2020 1:22 PM UTC
Yes, Windows 10 is supported for Windchill 11.2, but only as a test system, not  for production. Production Windchill systems need to be a Server version of Windows. PTC also recommends that your test and production systems be on the same OS in case there are any issues.
Jun 29, 2020 1:26 PM UTC
It is only supported for Development and Test Systems Support
Refer to this Software matrices > https://www.ptc.com/en/support/refdoc/Windchill_PDMLink/11.2/WindchillSoftwareMatrices_11_2_1_0
Navku14-AlexandriteAuthor
Jun 29, 2020 7:56 PM UTC
But when I do install Windchill in my windows 10, It is taking Product install dir is \opt\ptc\Windchill_11.0.  which is a Unix system folder.
The exact installation log attached below.
How to run with actual folder where it is available?
Jun 29, 2020 8:24 PM UTC
Did you extract the files from the ZIP download first?
Did you run Setup from the PTC Solution Installer folder?
Are you running directly from a DVD?
From the log file, it looks like you navigated deeper into the install scripts than you needed to and did it from the zipped file.
