Feb 14, 2025 2:44 PM UTC
Integration of Windchill Workgroup Manager (WWGM) 13.0.1.1 with Creo
I have installed Creo Parametric 11.0.3.0 and Creo Parametric 10.0.7.0 along with Windchill Workgroup Manager (WWGM) 13.0.1.1. I am looking to integrate WWGM with Creo Parametric 11.0.3.0 and register it with a new server to enable seamless interaction and functionality.
Steps already completed:
  1. Creo Parametric 11.0.3.0 is installed on my system.
  2. Windchill Workgroup Manager 13.0.1.1 is installed and configured.
  3. I have previously integrated WWGM 13.0.1.1 with SolidWorks 2024 and AutoCAD 2024, but they are not functioning properly.
Issues:
  • Integration with Creo Parametric 11.0.3.0: I need to complete the integration of WWGM with Creo Parametric 11 and register it with the new server.
  • SolidWorks 2024 & AutoCAD 2024 Integration: These integrations are not functioning as expected. I am experiencing issues that block my daily activities, and I need assistance with resolving them.
Additional Information:
  • Operating System: [Provide your OS details, e.g., Windows 10, 64-bit]
  • Windchill Workgroup Manager Version: 13.0.1.1
  • Creo Parametric Versions: 11.0.3.0 and 10.0.7.0
  • SolidWorks Version: 2024
  • AutoCAD Version: 2024
Please assist me in:
  1. Completing the integration process between WWGM and Creo Parametric 11.0.3.0.
  2. Investigating why the integration with SolidWorks and AutoCAD is not functioning, despite successful initial setup.
  3. Providing guidance on troubleshooting and resolving these issues to enable smooth operation.
This issue is blocking my daily activities, and I would appreciate prompt assistance in resolving it.
Thank you for your support.
Regards, Vinit Kumar
avillanueva
23-Emerald II
Feb 14, 2025 7:21 PM UTC
Creo Parametric does not work with  WWGM. It has native connections inside of it. WWGM is not needed for Creo Parametric to connect to Windchill.
avillanueva
23-Emerald II
tarik_perc
Feb 15, 2025 10:18 PM UTC
Hello @VB_12246828
As @avillanueva mentioned, Creo Parametric in its recent releases no longer needs Workgroup Manager, it connects directly with Windchill PLM via "Direct Link", you only have to check the compatibility between Creo and Windchill in Software Matrices/Release Advisor.
See Article - CS262259 - A new Direct Link to Windchill option has been introduced in Creo Illustrate 4.1
You still need to install WWGM for Solidworks and AutoCAD, again you need to confirm that your stack are compatible with each other via Software Matrices/Release Advisor.
Link to Release Advisor
Community Moderator
Mar 11, 2025 8:01 PM UTC
Hi @VB_12246828,
Anurag
prerev_kompan
Jun 25, 2025 8:46 AM UTC
Hi
We discovered some time back, that during installation of WWGM we need to add several or all versions of SolidWorks and AutoCAD to the installation, otherwise we couldn't connect.
Don't know why, but it solved the issue.
ScottMorris
Jun 25, 2025 5:40 PM UTC
Be sure to check the software compatibility matrix for WC WGM to make sure you are connecting supported versions of CAD apps to WGM
https://www.ptc.com/support/-/media/support/refdocs/Windchill_PDMLink/compatibility/WWGMCompatibilityMatrix.pdf?sc_lang=en
