Intralink 10.0: "Out of Date" Indicator?
Fellow 'chillers:
When looking at the Intralink 10.0 m030 interface in the Embedded Browser (in Wildfire 4 m210), how can a user know that there is an "Out of Date" CAD Document in his Workspace?
The reason I ask is this: In the old world of Intralink 3.4, there was a column in the Workspace interface which clearly stated "Out of Date". The user then knew to Update his Workspace to bring down the current version from Commonspace.
But in Windchill-based Intralink 10.0, even after performing a Synchronize the user does not see any visual indication in the Workspace interfacetelling him that he has "Out of Date" objects.
The only indication of "Out of Date" objects presented to the user seems to a be when he tries to perform an edit on an object in ProE, is presented with the dialog box to "Check Out Now", but the Check Out fails. It is only when (if)the user notices the miniscule failure symbol in ProE then checks the Event Manager that he is presented with the errormessage stating the version of the object in Commospace does not match the version of the object in his Workspace.
Is everyone facing this same situation? Or is there a configuration issue here I could fix?
TIA.
