6-Contributor
Aug 3, 2015 8:06 PM UTC
Intralink 10.1
How do I change a version/revision value after the file has been checked into common space? I want to change revision "B" back to revision "A" in common space.
BenPerry
Aug 3, 2015 8:18 PM UTC
It is possible using Windchill shell, and the command wt.vc.ChangeRevisionLabelUtility.  (CS31039)  But it requires that there are no pre-existing revision A's.  Does that fit your use case?  Or do you want to merge more B iterations into existing iterations of A?
sdicarlo6-ContributorAuthor
6-Contributor
Aug 3, 2015 8:46 PM UTC
The revision was changed from "A" to "B" and checked in. I want to keep the updates that were made to the CAD file, but I want the revision to be "A" instead of "B".
BenPerry
Aug 3, 2015 8:49 PM UTC
I don't think there is a way to accomplish what you would like.  I think this has been a long-running complaint, too.
If versions A.1, A.2, A.3, and A.4 exist ... and then B.1, B.2 are created ... we can't change the B1 and B2 to A5 and A6.
