Intralink 9.1 M060 Oracle install failure
  • October 31, 2012
  • 0 replies
  • 529 views
All,
Has anybody running Intralink 9.1 M060 been able to successfully perform the Oracle portion of the install recently?
This is a crucial step in order to perform a restore from backup or rehost.
This used to work but now the install fails at the step when the installer attempts to register with Oracle over the internet.
As a test we did the following:
· Install the Windows 2008 server OS (service pack 2) on a virgin machine
· Directly connect to the internet - We are not behind any of our corporate IT department's security systems
· Turn off Windows firewall
· Enable telnet and verify that this telnet command doesn't fail:
o telnet ccr.oracle.com 443
· Copy in the following install media:
o CD-2200B-108_2009000_Oracle_11g
o CD-60419-091_M060_3rd_Pty_Sfw
o CD-60492-091_M060_Oracle_Sfw_Asst
o CD-60703-091_M060_Java_Dev_Kit
o CD-60800-091_M060_Dir_Server
o CD-60702-091_M060_Soln_Instlr
· Run C:\CD-60702-091_M060_Soln_Instlr\setup.vbs
o Installer selections are all defaults unless noted here:
o Advanced
o √Standalone Product or Component
o √Java, √WindchillDS, √Pro/INTRALINK Oracle (osa), √Oracle Configuration
o Leave these two preselected: √Create Database, √Create Windchill Database and User Account
o Oracle 'SYSTEM' Account Password: xxxxxxx
o Oracle User Name for Windchill: wcoracle
o Oracle User Password for Windchill: xxxxxxx
o LDAP Server Administrator Password: xxxxxxx
o √Use Staging Area
o Install
· The install fails with the following written into this log file:
C:\ptc\Windchill_9.1\osa\oraprod\cfgtoollogs\opatch\opatch<date stamp=">.log
INFO:
Invoking "cmd /C "C:\ptc\Windchill_9.1\osa\oraprod\ccr\bin\setupCCR.exe -R C:\ptc\Windchill_9.1\osa\response\ocm.rsp -S OPatch -V 11.1.0.6.5" under "C:\ptc\Windchill_9.1\osa\oraprod\ccr\bin"
INFO:
** Installing base package **
Deploying core - Version 10.3.0.1.0
** Registering installation with Oracle Configuration Manager server(s) **
Failure in registering with Oracle Configuration Manager server
Error connecting to server.
peer not authenticated
I'm starting to think that the installer attempts to communicate with the Oracle internet site in a way that no longer works due to some change at Oracle.
Mike Foster
ATK
