Mar 11, 2021 12:53 AM UTC
Introducing eSupport tools to help you troubleshoot Windchill Stability issue
We are happy to introduce one new tool on the eSupport site! This tool is designed to quickly get you the information you need in one place without having to search for it.
The Windchill Stability Troubleshooter  is designed as a wizard. It will help to guide you to the most common solutions for Windchill server stability. Most issues are complex. Within a couple clicks you can review the most common solutions for that specific issue. Many of these solutions have links that open a popup window for more detailed steps.
Our knowledge experts are actively monitoring your feedback and continuing to enrich the content. Even if you’re not currently having a Windchill stability question, take a look and tell us what you think!
22-Sapphire I
Mar 11, 2021 4:54 PM UTC
Looks great.
Note: May want to use a D:\ or higher drive for the example Windchill install location.  The example has C:\, which likely is very rare.  Also, may want to use 11.1 or higher since 11.0 support runs out very soon.
Mar 11, 2021 5:16 PM UTC
I would suggest E:\ or higher as D:\ is typically a CD/DVD device for loading files.
We never use the C:\ drive for loading files as that is usually a smaller disk size for the OS only.
Maggie_Ma14-AlexandriteAuthor
Mar 12, 2021 5:35 AM UTC
Good idea! updated!
ScottMorris
Mar 12, 2021 12:06 PM UTC
Can you tell me how can I find this tool on the support site? The link here is great, but it would be nice to know how to navigate to it on the PTC Support site.
TomU
Mar 12, 2021 1:58 PM UTC
It would seem this is classified as a 'Digital Service' and there are over a 1000 of them:
I wasn't able to find a central launching point by product either, so maybe the search tool is the only way.  Of course the bummer with that is you have to already know what it's named.
Apr 13, 2021 9:34 AM UTC
WST was updated on:
1. Added 2 errors to page ms-not-starting-withlogs:
1). javax.naming.AuthenticationException: LDAP: error code 49
2). java.security.KeyStoreException: Could not load keystore file
2. Added below keywords to improve WST findability
- Stop call received in Method Server
- Could not initialize auditing service
- javax.naming.CommunicationException with LDAP directory server
- Oracle ORA-nnn error message
- OutOfMemoryError
- SQLServerExceptio- error
- SSL related error
- com.infoengine.* error
- WTRemoteException: Unable to register server
- NoClassDefFoudError
In addition, the survey to customer is now go alive.
