Sep 18, 2024 2:28 PM UTC
Inventor Lable to Windchill Refrence Designator
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.0
We are trying to map an Inventor lable to the Windchill attribute to Refrence Designator.
The out of the box solution is to map the full occurence name from Inventor to Refrence Designator, is there a way to change this mapping?
Either to make use of the Instance Property feature in Inventor or to change the string when capturing the Occurence Name?
Current result is: Inventor "Occurence Name" 123::90500-2500:1 maps to Refrence Designator 1 to 1: 123::90500-2500
Is it possible to set it to only capture the "123"?
Here are the errors that I faced
N/A
    Catalina
    Community Manager
    Sep 24, 2024 9:04 AM UTC
    Hi @LM_10797368,
    Thank you for your question!
    Best regards,
    Catalina | PTC Community Manager
