Jul 10, 2015 6:39 AM UTC
Inventor Worker "Apprentice"
Hi to all
Does anyone have experience with Inventor Apprentice as worker?
I have:
  • installed Inventor View 2014 with SDK 64bit on a windows server 2012 R2. I can start "D:\Autodesk\Inventor View 2014\Bin\InventorView.exe"
  • in Worker Agent Administration a Inventor Worker configured.
  • ran the inventor2pv_config.exe and selected "Start in Apprentice Server Mode"
  • in the <Setup_directory> (D:\ptc\inventor2014_worker) all the necessary files where createt
When starting the INVENTOR:1 worker i have following error in worker_0.log:
inventor2pv Error:70001: Failed to Start Apprentice Server Application [-2147221164]
Unfortunately I can not find anything in the PTC Knowledge Base
thank you very much
daniel
Jul 12, 2015 9:15 AM UTC
Hi Daniel,
May I know what version of Windchill?
I would recommend you to check the compatibility matrix here http://support.ptc.com/WCMS/files/157177/en/Windchill102M030CADIntegrationMatrix_061215.pdf
Workgroup manager can only be installed on Windows 8.1 or Windows 7, i guess.
Shashi
