Aug 19, 2015 2:46 PM UTC
Is Info*Engine included under a Windchill license, or is it a seperate purchase?
The software for Info*Engine appears to be downloadable, but I am unclear on the licensing requirements.  Thanks for your help.
2-Explorer
Aug 19, 2015 3:04 PM UTC
Info Engine is default component for all Windchill Installations and it is required to complete the installation of Windchill. There are several functions in Windchill which are dependent on I*E. So all WC users will have I*E in the download list and will be installed in all the installs.
From a license front, if you use I*E for basic tasks/customizations within the system you don't need to procure any additional I*E licenses. If you are using it for interrogations with other data systems then they would need to buy additional licenses
Binesh Kumar
pnelson1-VisitorAuthor
Aug 19, 2015 3:07 PM UTC
Thanks for replying.  Our interest is specifically for the ERP Connector functionality, which I believe is included in Info*Engine.  Is that correct?
2-Explorer
Aug 19, 2015 3:54 PM UTC
That's correct. ERP connector requires Info*Engine External Server Access license. This is 1:1 with Windchill Heavy and light licenses.
Binesh Kumar
