Jul 1, 2026 2:57 AM UTC
Is it a known limitation that we cannot copy an operation
I am using Windchill MPMLink Release 12.0 and Datecode with CPS 12.0.2.9 When working in Windchill, I am unable to copy an operation from the folder view and paste it into the Process Plan structure tree using 'Paste Special
HelesicPetr
Jul 1, 2026 8:21 AM UTC
Hello ​@takeshiokamoto
It is known limitation. copy paste function does not work in that combination in earlier versions.
the MPMLink structure is isolated area from copy function in standard PDMLink place as a folder, search results etc.
I created an idea to cover this possibility long time ago, and the idea has been implemented for Windchill 12.1+
so there is a hope that it will work also for MPMOperations
PetrH
HelesicPetr
PetrH
Jul 1, 2026 8:33 AM UTC
Hi PetrH,
Thank you for your prompt response. I understand.
I'm glad we had the opportunity to connect through the Community. I'll continue to make use of it in the future.
Best regards,
T. Okamoto
