Oct 19, 2015 4:30 PM UTC
Is it possible to automate the following re-host scripts from the Rehost Utility Guide? Publishing Configurations from source to Target, Thumbnail Generation Configurations from source to Target and Dynatrace PSM Agent Configurations from Prod to Non
1. Publishing Configurations from source to Target
2. Thumbnail Generation Configurations from source to Target
3. Dynatrace PSM Agent Configurations from Prod to Non-Prod
Thank you,
Jimmy
2-Explorer
Oct 19, 2015 10:40 PM UTC
Are you talking about the configurations which you do in Publishing and Thumbnail configuration? This is mostly stored in database and it should get moved from source to target when you import the database
Dynatrace PSM agent configuration basically has 2 things. 1. Agent files and 2. Configuration in psm-wt.properties.xconf. I don't think, this will be handled by rehost guide.
Thank you
Binesh Kumar
Barry Wehmiller
