Feb 3, 2016 10:16 AM UTC
Is it possible to create a Manufacturing View in different folder than Design View?
In OIR we added some code so the folder location during WTPart creation is set based on the View.  However this won't seem to work when creating a New View Version of an existing WTPart.  The only way to make it work, is to give Create and Change Domain permission for the Manufacturing Engineer in Engineering Domain and ask him to Cut and Paste the Manufacturing View into the Manufacturing folder.
Windchill 10.1 M030
23-Emerald II
Feb 6, 2016 12:02 AM UTC
Sven,
Does this help? It has to do with moving specific view versions to a different folder:
http://support.ptc.com/cs/help/windchill_hc/wc101_hc/index.jspx?id=WCUpgradeCFTR_MoveSpecificViewsVersions&action=show
Feb 8, 2016 6:33 AM UTC
Thanks for your answer.  Actually I'm looking for a way to automate this using OIR.  Currently we are using OIR to choose folder depending on view.id.  This works for New Part creation.  It doesn't work for New View Creation; the new view is always stored in same folder as orignal view.
I know from Windchill 10.1 M040, a new feature has been added to the Move action, but this is still a manual action.
GregoryPERASSO
Feb 8, 2016 8:27 AM UTC
Hi
not possible OOTB
you can add the folder in the layout to let the user choose another folder than the Design view.
We achieve this by customization ....
regards
7-Bedrock
Jul 18, 2018 3:46 AM UTC
Hi Sven,
Could you please post the changes to OIR here. I am trying to setup folder location based on View in the New Part creation wizard, but unable to do so.
Pooja
