Sep 11, 2023 7:23 PM UTC
Is it possible to edit select affected objects page in create change request wizard?
Is it possible to add like a description/instructions on this step 2 of creating a  change request?
HelesicPetr
Sep 12, 2023 6:00 AM UTC
Hi @RG_10753677
OOTB it is not possible to add a editable parameter by table view created on the RelevantRequestData2.
System do not allow you to show the attribute from that link.
but you can customize the table builder and processor to save the value by coding.
I did some thing like this for change task
PetrH
18-Opal
Sep 12, 2023 10:48 AM UTC
Petr,
I think @RG_10753677 is asking if he can add text to step 2 that gives the use clear instructions on what the heck they should do.
@RG_10753677 , can you confirm you want to add text to the page to give the users clear instructions on what they are expected to do at step 2.
David
Sep 12, 2023 1:00 PM UTC
Yes, @d_graham
I want to add instructions/steps-to-follow, basically like information for the user what exactly they need to do once they are in that window/wizard.
