6-Contributor
Aug 17, 2023 1:03 PM UTC
Is it possible to get the active config spec of a part structure in a data utility ?
I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020-CPS26
Is it possible to get the active config spec of a part structure in a data utility ? I would like the data utility to display a value based on if a link to a parent part exists and need to filter the parents by type and variation2.
cgautierAnswer
18-Opal
Sep 11, 2023 2:36 PM UTC
Hello carlh42,
You asked some question regarding Windchill, thanks for reaching out.
This is Charles from PTC Technical Support in Europe, I will provide you assistance on this question: fyi the config spec is a client-side information, you can also review kb article CS250921.
KR,
Charles.
HelesicPetr
Aug 18, 2023 5:50 AM UTC
Hi @carlh42
I try to get the selected structure filter from the structure for many years. I also contacted PTC for help, but I have not found a solution. PTC does not help.
I could get the saved filter setting but not the active one so from my perspective it is not possible (I hate to say that because I have not found a solution yet)
PetrH
carlh426-ContributorAuthor
6-Contributor
Aug 21, 2023 8:10 AM UTC
Thank you for your reply.
Carl
18-Opal
Aug 22, 2023 10:30 PM UTC
The active config is set on the client side not the server side. Because of this I tend to agree with @HelesicPetr (who knows what he’s doing, no doubt about that), I don’t think it’s possible either.
Just curious, what is the use case?
