Apr 18, 2022 5:43 AM UTC
Is it possible to make changes to "Any-level Occurrence Assignment" after creating a process plan
I am using Windchill MPMLink Release 11.0 and Datecode with CPS M030-CPS11
创建工艺计划后 “任意级别具体值分配” ,是否可以进行更改
Translated with Google Translate
Translated by Corina Ionescu, on April 18th 2022
HelesicPetr
Apr 19, 2022 6:58 AM UTC
Hello @PC_9627923
No it is not possible by user interface.
If you have access to a database then you could change it directly by sql command. But I don't know consequences what the change may case.
PetrH
18-Opal
May 2, 2022 1:59 PM UTC
Hello PC_9627923,
As stated in knowledge database article CS278222: This attribute (Occurrence Allocation From Any Level) value cannot be changed once the Process Plan has been created.
I remain at your disposal for any questions or concerns.
Kind Regards,
Charles Gautier.
18-Opal
May 23, 2022 8:00 AM UTC
Hello PC_9627923,
Will you need further help on this question?
KR,
Charles.
