Mar 13, 2020 8:36 PM UTC
Is it possible to pass multiple strings to Windchill for a Cognos report
Hello. I am currently attempting to create a Cog nos report that allows a user to select multiple contexts  with a select and search prompt with multi select and pass them back as parameters for a Query Builder report, however when I try to I can only seem to pass the first selected value in the list. Is there a way to pass them all back as a Comma separated values?
Mar 18, 2020 1:59 PM UTC
Dbellisario,
Perhaps you are looking for this?
https://www.ptc.com/en/support/article/CS59991
I would suggest opening a Support case if not, so that one of the engineers who specializes in Cognos reports might be able to assist or confirm this with you.
Mar 18, 2020 2:44 PM UTC
Hi Michael,
Unfortunately that wont work. Its not the passing of attributes from Cognos to Windchill the problem. Cognos cant seem to send a comma separated parameterized string to Windchill from a multi-valued search and select prompt. It only sends the first value. It looks like TS is the route to go. Thank you for your assistance.
