Oct 4, 2018 8:31 PM UTC
Is it possible to use an OIR to default an alias attribute?
Looking for a method to set a default value for an alias attribute on a Change Notice object.  Any ideas?
Jul 25, 2019 6:41 PM UTC
According to following article, it doesn't look like there is a way to do this.
https://www.ptc.com/en/support/article?n=CS135306
Jul 25, 2019 6:50 PM UTC
That article is junk.
The resolution does not directly answer the question. Working to product spec means what, Yes or No? Inferred by the second line that the answer is no, but it is ambiguous.
Jul 25, 2019 6:52 PM UTC
I am with you on this one, the answer is unfortunate no. I will have the article updated to reflect this information clearly.
Fadel
23-Emerald II
Dec 23, 2021 3:44 PM UTC
The alias attributes by definition are not persisted in the DB , therefore it doesn't make sense to assign a default to something that is not stored anywhere.
The value of any alias is calculated on the fly when displayed .
I hope this helps .
Buiꓘa
