avillanueva
23-Emerald II
Dec 14, 2023 2:45 PM UTC
Is setting wt.fv.fvFileThreshold needed anymore?
I am moving vaults to a new NetApp volume and making long overdue changes to automatically create folders for that vault. I have 3 vaults that I will reduce to 2 so wt.fv.forceContentToVault is set to false properly (https://www.ptc.com/en/support/article/CS68929?source=search. I also have the following set:
wt.fv.useFvFileThreshold=false
wt.fv.useVaultsForAllContent=true
I know in the past we hit some NetApp or OS limit on the number of files in a single folder but I think that limit might not exist (except for max number of files on entire volume). The vault folders currently have anywhere from 100K, 300K to 1M files in them and I have had no issues (xfs or ext4 I think). So the question is, does setting a limit even matter anymore?
avillanueva
23-Emerald II
Dec 15, 2023 12:54 PM UTC
550K files in a single folder after revaulting. My main vault has 13M files so I may set a limit just for sanity like 1M but its not for any technical reason. @HelesicPetr mentioned hit if you happened to peer into those folders so no harm in putting a limit.
HelesicPetr
Dec 14, 2023 4:46 PM UTC
Hi @avillanueva
It was a limit of explorer that can show.number of files
Aslo it was performance issue. If there were 1M + files it took ages to load sometimes it was imposible to load all files..
I don't believe that Microsoft has solved that issue 😄
PetrH
avillanueva
23-Emerald II
Dec 14, 2023 5:01 PM UTC
Same on RHEL but I never really cared to browse the vault folders.
Dec 14, 2023 5:04 PM UTC
I have mine set at 50,000 but I am using Windows Servers.
I found some references that indicate it is a Microsoft limitation of the index file they use for each folder.
TomU
Dec 14, 2023 8:09 PM UTC
It's enabled out of the box by default now at 50,000 files, so unless you explicitly change it, that's what you will get.
avillanueva
23-Emerald II
Dec 14, 2023 9:10 PM UTC
Unless use threshold is set to false. I am at 156000 files and counting as it revaults.
