18-Opal
Nov 13, 2017 9:10 AM UTC
Is SQL Server included in PSI?
Hi i'm seonho
We are re-reading the Windchill Installation Guide.
Or should I install it separately?
thanks
TomU
TomUAnswer
Nov 14, 2017 1:25 AM UTC
Yes, either Oracle or SQL Server needs to be installed and configured prior to installing Windchill.
You probably should read through the installation guide and other related documents.
https://support.ptc.com/WCMS/files/168349/en/WCInstallConfigGuide.pdf
Nov 13, 2017 10:37 AM UTC
It is not included in the PSI.
CHASEONHO18-OpalAuthor
18-Opal
Nov 14, 2017 12:20 AM UTC
should i installed SQL Server?
before i installed windchill,I have not installed SQL Server separately.
TomU
TomU23-Emerald IVAnswer
