Feb 12, 2013 11:45 AM UTC
Is there a way to change the type of a WTPart?
Hi All,
Is there a way to change the type of a WTPart through UI or through any other method? Is there a tool to convery WTParts from one type to another in bulk?
Prabhakaran V.
GregoryPERASSO
Feb 12, 2013 12:25 PM UTC
unfortunately, only by customization.
And this is not supported by PTC....
Feb 21, 2013 4:20 PM UTC
There is a tool to do this:
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS7287
The tool will generate a SQL script you'll need to execute. You can change the SQL script so only parts in a certain product/library are converted.
best regards,
Stijn
Prabhu10-MarbleAuthor
Feb 22, 2013 3:55 AM UTC
You are correct Stijn.. Got the tool from PTC. Looking for ways to manipulate it to our needs.
This tool would convert all, I mean ALL, parts in the whole system from one type to another. Need a way to do the same selectively on specific parts.
Will update if we get to succeed.
Prabhakaran V.
Mar 11, 2015 2:12 PM UTC
You can do it like this:
Oracle:
UPDATE WTPart
SET branchIdA2typeDefinitionRefe = 126962,
Ida2typedefinitionreference = 126966
Where Branchida2typedefinitionrefe In (36374)
AND Ida3masterreference in (select ida2a2 from wtpartmaster where WTPartNumber in ('2000783'.'2000789'));
MS SQL:
UPDATE pdmlink.WTPart
SET branchIdA2typeDefinitionRefe = 61479,
idA2typeDefinitionReference = 492826
WHERE branchIdA2typeDefinitionRefe IN (71144)
AND idA3masterReference IN (select idA2A2 from pdmlink.WTPartMaster where WTPartNumber in ('2000783','2000789'));
