Mar 30, 2017 10:50 PM UTC
Is there a way to delay auto-numbering in Windchill 10.2?
Currently, the auto-numbering kicks in and renames all components according to the auto-numbering scheme when opening a 3D model in CATIA that is not saved in Windchill. I would like to delay this action until the 3D model is saved in Windchill.
I came across this preference in Windchill 11.0 that seemed to be what I need, delay.autonumber.generation which allows you to switch behavior and delay number generation. Does anyone know if this setting is available in 10.2 and if yes, would it change the above behavior to what I want? If not, is there an alternative way to do it?
Thanks much in advance!
hthakreAnswer
Apr 4, 2017 7:14 PM UTC
The preference you have mentioned (delay.autonumber.generation) is specific to Creo Elements direct which is not expected to work for CATIA.
Also Preference is introduced in Windchill 11 only, so it will not be applicable in 10.2_M030.
hthakre5-Regular MemberAnswer
